I want to achieve the exact seasoning color of the attached image.
Can someone guide me.
Seasoning color|375x500
Seasoning color 2|375x500
Hi, I want to achieve the exact seasoning color of the attached image. Can someone guide me.
Food R&D Emeritus reply
postedyou can enhance that with little liquid caramel coloring..Then compare the resulting color by comparative colorimetric means ...
Ogunleye Oluwadunsin Augustine reply
postedHave used liquid Caramel E150d but I am not getting the desired results
postedIf you had the ingredient composition of yiur benchmsrk then reformulate it accordingly...If it has brown sugar then use darker brown sugar finish it with darker powdered or liquid caramel. R&D work is knowledgeable work with combined common sense and persistence until you get it right..
I presume you just did trials with not much thought but just literallydoing things trial and error.
If at the end you still cant duolicate it in color exactness, in spice or seasoning mixes, the flavor or taste is more important than the appearance if you were able to get it identically..
postedThanks very much, it is really helpful.
Have gotten the taste and the flavour, remaining the appearance. I will try everything possible.
