Hot fill closure bore inner plug damage
Dear all, My Mango juice is filled in the PET bottle and the closure inner seal intigrity bore plug damaging and allowing the product to leak. Kindly suggest to avoid the problem.
Consult your equipment supplier bow troubleshoot that problem…
Hello, it may be due to your packaging material, try to inspect the packaging materials before use
Hello Mr Anil
Shock cooling, which you will apply when you spray a pulverized water with a small hose, coinciding with the outlet right after the bottle is closed and the part that is completely closed, which will solve your problem to a large extent. Please make sure that the sprayed water coincides with the full cover and immediately without closing it.
