Why Conducting Regular Audits?
Even if your business’s HACCP is highly effective in theory, it won’t prevent contamination unless actual practice lines up with documentation. Regular audits can ensure employee practice complies.
HACCPs are structured around identifying both potential food hazards and [critical control points] (CCPs) where your system has the opportunity to prevent, mitigate or eliminate a potential issue. Usually, this means storing food items or performing some biological, physical or chemical action to a target limit— like a specific temperature—to prevent or mitigate contamination.
For example, in the manufacturing of chicken products, cooking and hot-holding are critical control points at which the product needs to be heated to a certain temperature to eliminate or prevent potential hazards. Here, an audit would be a chance to ensure employees cooked and hot-held foods at the proper temperatures. If they aren’t, the food safety management team can make policy changes that ensure practice lines up with planning.
The audit process should be consistent and occur regularly. It should also cover every aspect of your HACCP strategy and place a particular focus on potential hazards and CCPs. These audits can be a way to uncover the strengths and weaknesses of your current HACCP strategy. Companies can use this information to build upon existing practices or demonstrate how procedures could be more effective.
