Prepare yogurt from soya milk
Hi. It possible, my classmate did this has her project and it worked. Soya milk makes a very good and tasty yoghurt
might be possible, but then the next question is then why is this not available so easily in the market?
Many kinds of soymilk based desserts, frozen curds, various flavor based soft gel types are all available in the market- However these are not with the typical yoghurt taste (never named as yoghurt too), but a curd out of soymilk with its own specific taste highly appreciated by the Asian consumers.
Slight acidic tinge imparted by GDL, if otherwise other calcium salts used for the curd preparation.
Thanks for your reply i will try an see how it will go
Thanks i must will try this
Can I have the processes please.
I will definitely give you the procedure if works lemme make trial
Can I produce yoghurt of soya added with milk . Can it will increase protein in milk and all together can produce yoghurt with good quality
Soya yogurt by itself is already good quality and its suited for vegans …if you add dairy milk you are making non dairy labeling difficult.
