My egg free mayonnaise watery after few days
Hi everyone one pls help me
My receipe is here for 100kg batch classic
Maize starch=9kg
Water=55kg
Salt=1.250kg
Sodium benziote=110gm
Potassium sorbate=11O gm
Acetic acid =800gm
Aspartame =40gm
Soya bean oil=2kg
Xanthum gum=400gm
Gaur gum=400gm
Tio2=150gm
Water=40kg
Pls help me
Ask yourself whats in the egg aside from lecithin thats absent in your recipe that stabilize mayonnaise ?
If you realize that then you can solve that problem.
The rule in replacement of ingredients is pretty simple ; know what are the components of that material and whats its functionality in a particular application. Then from there source out viable alternatives that would fulfill that functionality…
If you did not think if it in that way…then you are not qualified to do the work you are assigned.
Hi…
From the concept of mayonnaise preparation, the most important component is the egg- which you replace with soya bean oil.
I can just imagine your product separation- water separating from the oil. This means you lack the ingredient to replace the lecithin- which is inherently present in the egg. The lecithin enhances emulsion stability and improves product appearance and texture.
So, add an ingredient in order to emulsify the oil and water and other ingredients.
maria luz bayan
You havent emulgator in your recipe. You must add emulgator. There are alot of chemicals using for emulsions.
