Guidance regarding article writing
Need guidance for selection of topic and writing research article in the field of food chemistry
Do explain the topic: is that a research paper or review article.
Also check if this might help you to understand the process:
Thanks for sharing this materials, it is quite helpful.
Now, kindly help me to choose the topic for review article in the subject of food chemistry.
Thanking in anticipation.
take one step at a time and you will be able to do it.
That’s too much. already as you are given the clues and means to approach and you want everything to be spoon fed to you…?
If someone will give you what you need, are you that shameless to claim it as your own work…?
ITS your project and if you had thought of that in the beginning then you had already a solid understanding of the subject matter.
If not then you are in a far worse mental state unbecoming of a good student i advise change your course as you don’t have the aptitude in the subject that might become your career in the future…
