@Azamat sorry, what do you mean?
Reading some of your explanations, I also thought about the temperature. If the you fill at a high temperature and then store the product at a low temperature, vacuum may form. When T drops in a closed system, P also drops hence shrinking packages that appear to be packed under vacuum.
Hi, I hope you are still active this website. Could you please explain what was the root of the issue and how did you solve it?
Do you have a similar problem?
Yes, my friend is experiencing the same issue during packaging. The package is being vacuumed form itself after has sealed. However, the problem doesn’t occur with every package. We noticed this issue, so I wanted to write about it here.
Let’s discuss this on a new topic, adding photos can help to understanding of the problem.
