Food anti-caking agent
Food anti-caking agent Hi all! Tell me, please, maybe someone understands anti-caking agents. I need an anti-caking agent that will prevent clumping and caking of the powder. The powder consists of several components (glucose, salt, sodium citrate, citric acid, sodium and potassium chlorides). Ideally, the anti-caking agent should dissolve in water and of course be harmless to humans. What is the best anti-caking agent in your opinion? One technologist advised to use bentonite and cellulose. Bentonite as a moisture-retaining agent, cellulose as an agent to aid in powder flow. But both agents do not dissolve in water, plus bentonite gives a black precipitate. Silicon dioxide is often used, but it also does not dissolve in water and precipitates. Maybe there are still good options, I would be grateful for the answer!
Try calcium silicate
Hi Inchcape,
Don’t forget the humidity content of the packing mixing area.
Install dehumidifiers and aim for <70% R.H. at all times.
Also use poly prop packaging as a moisture barrier as it is far superior the poly ethylene.
Cheers,
Kevin
Magnesium stearate
https://fstdesk.com/t/silicon-dioxide-replacer/14076
