Which raw materials should I use in drop chocolate so that the drop chocolate does not melt in the cake?
Good day Cemile,
You can try and use a fat that has higher melting points so that when you incorporate them in your batter before baking, it will not melt during baking.
If it’s used as coating inclusion of higher melting point fat that is compatible with your chocolate is the best step.Non lauric Cocoa butter extenders for real chocolates, Lauric fat ( Hardened Palm Kernel oil HPKO) fir compound coating.
Sorry for being late , there are special type of palm kernel fractions . You will find Hepa 60 as a commercial name , that is derivates of Tristearat . So generally producers are using this in their compound or real confiseries ( drops , cuvertures etc) to provide more heat resistance .
