Hello we want to roasted salted sunflower kernels produce but our salt not sticking to our kernels how i can do it to stick the salt to kernels
Which glue agent do you use? And please provide more info about your process technic.
@Azamat
Do you really need visible salt crystals on your sunflowers seeds or you just want s properly salted roasted seeds ?
Hi Azamat, use some sort or precooked starch dispersed and swelled in water. Rice starch is easy to use, is neutral and has good binding and filming properties. Starch also provides a whitish look and crunchy texture.
hello
we use gam arabic 75 g for 10 lt water maid mix
1 lt mix put to 50 kg unroasted sunflower kernels after mix we put 500 g salt and roasted it belt oven
@Azamat…so you can taste the salt but its invisible on the surface, ?
Or the salt drops off during baking…?
Maybe you need tight binding as well as bigger salt particle size so it will remain visible .
When we make salted pretzels the salt particles are visible on the pretzel surface …
hello, if you do your transactions using 0.006 arabic scale, you will get all the results you want. Good luck with
