You need readings of pure oils.
Lemon juice and oil reading(Ph3-5)
and to negate acid, you should do the same ratio as oil and lemon juice, but with water alone (Ph7) .
Yep, but shelf life will be an issue ?
Not really. The pH is still low enough to give a good shelf life.
