Changes in Cashew Apple Juice Flavor after Tangential Microfiltration Process
Abstract
Cashew is a highly nutritive fruit native to Brazil, but the high astringency of its integral juice limits its acceptability and consumption. Using tangential microfiltration process it is already possible to reduce up to 97% of the tannin present in the cashew juice.
Making use of this same technology, the present work studied the changes in the volatile composition caused by this process, monitored by sensory evaluation. Cashew juice was obtained from the processing of cashew apples in an expeller extractor.
The juice was clarified in a microfiltration pilot scale plant. Volatile compounds were extracted through vacuum evaporation, trapped into a polymer membrane and analyzed by GCMS. Difference-from-control sensory test was applied to verify aroma sensitive changes between the integral and clarified juice.
Cashew juice clarification by tangential microfiltration provoked a few alterations on the juice’s volatile profile, but these changes did not impair the characteristic cashew aroma in the clarified juice.
Download full article.
changes-in-cashew-apple-juice-flavor-after-tangential-microfiltration-process-313.pdf (2.6 MB)
> Citation: > de Andrade MIR, de Sousa ACR, de Abreu FAP, Ximenes SF, dos Santos Garruti D. Changes in Cashew Apple Juice Flavor after Tangential Microfiltration Process. Ann Nutr Food Sci. 2018; 2(4): 1029.http://www.remedypublications.com/annals-of-nutrition-food-science-abstract.php?aid=313
